Radius arms. which side is up - IRS First Time Rebuild
(Aristides Balanos) #202
Bushings are not that great in dealing with radial forces.
And I can’t see how, with metal to metal friction, they can hold their tolerances in time better than needle bearings…
When I had inspected mine, original bearings with 130.000 Km and almost 30 years of use, even with the felt seals but well lubed, they were still in very good condition and they are still in my car.
Aristides
(Mark Lee (Pay Pal Patron)) #203
Not this IRS. I assembled the hub last night and the bearing is snug, but not as snug as the other side. The end play could be adjusted with two screw drivers. This was handy cause I got the end play right where I wanted it and the shim/spacer turned out to
be the 0.140 which I have a bunch of. The other side however I’m gonna need a 0.127 naturally nobody has them on stock. Go figure.
I did decide to use the JB carrier well because I have to get the tools back. I have had them way too long and I feel really bad about that.
I’ve learned a lot in this process, and have discovered that I can set the proper end play and figure out what shim I need without the use of the mandrel. Frankly I think it’s easier,
the way I’m doing it either that or I’m doing it wrong and will be making a complete hash of the hub and carrier.
It
Sent from my BlackBerry 10 smartphone on the Verizon Wireless 4G LTE network.
(Frank Andersen) #204
The advantage of the mandrel is two-fold, Mark…
The mandrel ensures that the inner race is pushed on squarely. Secondly, the calibrated 0,15" shim gives a reference point for computing the correct shim thickness from the measured play from that…
The logic behind the mandrels was to locate the inner race with excessive play. It is easier to push the inner race further down the hub, reducing play, than to ‘lift’ the inner race to increase play.
Fitting the inner race without the mandrel is fair enough, but with a measured shim in place; the difference between the measured and desired play still dictates the proper shim to use…
Frank
xj6 85 Soc Europe (UK/NZ)
(Mark Lee (Pay Pal Patron)) #205
well either I was doing something wrong. of there is a lot of excessive play. :blush:
Also, in an earlier post, I understood what I read something about (I’m too lazy to search for it in order to quote it or I misunderstood) the inner bearing being able to move on a hub. The last carrier I put together, the inner bearing wasn’t as tight on the hub shaft as the previous one. I assembled it anyway, Am I going to regret it? and should I search for a new carrier assembly?
Thanx again
Mark
(Mark Lee (Pay Pal Patron)) #206
I posted a new video on installing the bearings in the inner fulcrum bearing with a bolt.
(Frank Andersen) #207
It is a press fit, Mark - pressed on with the mandrel, or whatever. Then, with the proper shim computed and installed - the inner race must be pressed home against that shim. If this is not done, the inner bearing will stay in its original 015" shim position - with excessive play.
However, when the driveshaft is inserted and torqued up, the inner race will be forced it contact with the installed shim - and the play should be correct. if everything was computed correctly…:slight_smile:
If the inner bearing is too loose it may cause it to slip on the hub - which is ‘not good’. However, ‘wasn’t as tight on the hub shaft as the previous one’ may not be alarming. the old one may have been grubby - or there was unwanted grease on the hub shaft? It’s a dry fit…
Frank
xj6 85 Sov Europe (UK/NZ)
(Mark Lee (Pay Pal Patron)) #208
Crap! well I think this is going to fall into the category of not good. for example, I can adjust the endplay with two screw drivers prying on the carrier against the water ring. the PO had, what looked like home made knurling with a drift to keep the bearing snug. Worse case it spins a bearing, right? when the hub is tightened on the axle, the bearing should also be tightened to the seal ring which is pressed against the spindle on the half shaft holding everything in place. kinda like the front wheel bearing and spindle arrangement.
Well this sucks!
(Frank Andersen) #209
In principle; the inner races are held in position by the drive shaft nut, Mark…
When you levering the hub carrier without the driveshaft fitted; the outer race pushes against the inner race. With enough force the inner race will move on the hub - this is, after all, how play is adjusted…:slight_smile:
The testing procedure assumes that leverage is just enough to take up the play - and assumes that the inner race is not so loose on the hub that it moves too easily…
With the driveshaft fitted and torqued up, the inner races are held to set play. In principle, while the inner bearings can move on the hub to close up the play, the forces acting on hub/carrier and the conic construction of the of the bearings ensure that the play is maintained as set…
But only friction between the inner race and hub prevents the race from spinning on the hub. How tight the fit must be I don’t know - no specs are given. But both the hub and bearings are precision constructs - so without visible damage or signs of hub wear it should be safe…
Incidentally; the same applies to the outer races - they are press fit into the hub carrier, and friction alone prevents spinning…
Frank
xj6 85 Sov Europe (UK/NZ)]
(Mark Lee (Pay Pal Patron)) #210
Those were my thoughts too, Frank. so I figured if I get the proper end play once it’s more or less assembled, then I should be fine. It looks like the PO took a drift and attempted to “knurl” the inner portion of the hub to get a tighter fit on the bearing / hub assembly. So I figure it is probably ok. I’ll find out, I guess. it’s a pretty easy service while on the car, so I’m not too terribly worried about it. I’m searching for a rebuildable hub to have as a spare. I figure I’ll have a rebuilt hub carrier assembly on hand just in case it turns out to be a boondoggle.
do you know what the exact placement of the bigger shims the ones that go on the outside of the fulcrum shaft assembly on the carrier? There are two shims for each side,
  • Do these shims go on between the tapered roller bearing and the inner felt seal retainer or
  • between the inner felt seal retainer and the outer portion of the fulcrum arm itself?
The PO had one side between the felt seal and the bearing and on the other side, only one big shim on the whole assembly. This shim was between the inner felt seal retainer and the fulcrum arm.
Here’s my thoughts on this.
The shims are pretty fragile, and are easily damaged, so I’d think between the bearing and the inner felt seal retainer. Being on the inside the shims serve their purpose as well as being protected from the outside elements. My placement is between the tapered roller bearing and the inner felt seal retainer.
Thanx again everyone!
Mark
(Mark Lee (Pay Pal Patron)) #211
The shims are pretty fragile, and are easily damaged, so I’d think between the bearing and the inner felt seal retainer. Being on the inside the shims serve their purpose as well as being protected from the outside elements. so My placement is between the tapered roller bearing and the inner felt seal retainer.
Thanx again
Mark
(Frank Andersen) #212
Such ‘modifications’ are questionable, Mark - but as you say…
Shims are there to ensure the inner races are running true, or ensuring proper play, to the outer ones. In principle, being factory set, recording the number and placement of shims at dismantling is best practice. With PO interference this may not be right…
From the bearing; ring abuts the outer race. The seal retainer (with the seal inside) - the seal in contact with the bearing. Then a large washer. Inside this assembly the smaller ring abuts the inner race. The small shims outside abuts the ring - and are meant to the the ‘rub’ from the whishbone…
If these shims are placed adjacent to the inner race they wont do that - and will slightly displace the ring, adding leakpoints at the seal. I’m not sure of the overall result of your changes - even if, as you say, it wont affect the shims function as ‘distance’ holders…
Frank
(Mark Lee (Pay Pal Patron)) #213
so the larger shim is supposed to go between the inner seal retainer and the (as you refer to it as the wishbone) I refer as the outer fulcrum. If I understand correctly, the shims serve double duty
  • work as a thrust bearing between fulcrum and the inner felt seal retainer and
  • a place holder for the proper spacing for the carrier bearing / mounting assembly
Essentially the shims are in the wrong place.
(Mark Lee (Pay Pal Patron)) #214
Well I’m making progress on the IRS. I have it nearly completely a part. I’ve published a new video on how to install races (though I’m sure everyone here knows how) and properly grease wheel bearings. Don’t click on the link, I screwed up big time & am trying to fix it. I will post a new link in about 30 min or so. The video is a two part(er) the next part will be assembling / installing the bearings and the races & setting the preload.
The next video will be installing the Diff input and output seals, maybe bearings. I’ll know more after today.
Thank you all so very much for your support. I’ve got 15 subscribers, for that I’m grateful - and most are from this forum. THANK YOU!
My goal is to have a set of play lists that go through all aspects of Jaguar (in my case XJ) repair, diagnosis, and mods. so those who want to take on repairing their XJ’s will have something to fall back on or look at in the process.
Thanx again,
Mark
(Mark Lee (Pay Pal Patron)) #215
HI,
Well that was a major youtube screw up; and that is what I get for not reviewing the video before uploading it. ANYWAY…
Here’s the fixed video for installing races and properly greasing wheel bearings.
Thank you for your kindness and not telling me to find another hobby. because you really suck at YouTube videos.
Thanx again,
Mark
(Mark Lee (Pay Pal Patron)) #216
Hi everyone.
Ok, well I’ve been working my to the center of the IRS; and I’m to the point of replacing the Differential output shaft bearings. unfortunately the crush collar is crushed and is prohibiting the outer bearing from “just sliding off”.
Since this is my first IRS rebuild so far, I haven’t run across anything too difficult to comprehend - just a lot of pieces to keep track of. Oh, and it didn’t help that the PO put the carriers together wrong. I’m not 100% convinced these carriers are going to last. I won’t go on about the JBWeld inner seal retainer. or the fact that the inner grease seal ring (on one was stuck on the halfshaft while the other side was left to spin. It is a tight fit, but not tight enough to keep it from spinning on the output shaft where the wheel hub meets the half shaft. So which is it? spin while not under load, or be stuck on the input shaft of the half-shaft…? I do digress as usual…
Diff housing output shaft bearings. I halft to say I was a bit surprised to discover these bearings are completely isolated from the diff lube; and require their own grease. Hmmm…
Again, back to the question at hand. putting these things back together. Obviously I’m going to need a new crush sleeve. According to The Book of Green, it states to lube everything up, assemble it, install the inner nut (not tight) take a torque reading of the inch lbs required to turn the output shaft (with the nut loose) then gradually (with a torque limiting screw driver?) continue to tighten the nut while maintaining the recorded torque (the nut finger tight). continue to tighten the nut until nearly all the end play is taken up and the crush sleeve is, well, appropriately crushed… This is severely paraphrased.
that all being said.
  1. A torque limiting screw driver or wrench that can be set to 4-6 inch pounds? Seriously? I don’t have one (mine starts at 10 inch lbs) and I don’t think I’ve ever seen one. Even if I did have one, or found one, it’s probably 1/4 inch drive and the nut that I’d be turning is 1-7/8’s. I can’t say I’ve ever seen a 1/4 drive 1-7/8 socket. oh, and it has to be REALLY deep to fit over the output shaft splines. Rant over.
  2. Is there an alternative way that the preload can be set?
I’m open to suggestions. Oh, I did note the number of threads, and marked the nut and the output shaft before I took it off though with new bearings, I’m not too sure those marks will mean anything.
Again, Open to suggestions.
As always, very grateful.
Mark
(tony) #217
without the expensive special dial type inch pound gauge, there are 2 things to try
  1. Using electronic luggage/fish scales, you can calculate the force applied to rotate the object
    (and keep it rotating)…they cost about $5 on Ebay, and weigh down to grams
  2. the breakaway torque to turn the pinion is higher than the (torque needed to keep it in rotation
    which is what you need to measure), so a regular inch pound wrench can give you a guide,
    just not a good guide, as its higher
(Mark Lee (Pay Pal Patron)) #218
Now that is a cleaver idea! However I did find a torque limiting screw driver, then I made a socket to set the preload on the output shafts out of
  • 2" or 50mm (diameter) x 4" or 101mm schedule 40 pipe steel pipe
  • 2 pieces of 3" or 76mm square of 1/8" or 3mm steel
  • sacrificed a 3/8" drive extension (not really I twisted the end off the other day.
Too bad, cause that was the last of my original took kit I got when I was 14 or 15 years old. Funny I just remembered that as I’m writing this thread… For what ever reason, I didn’t toss it in the garbage after I twisted the end off… Hmmm… Well I’m glad I didn’t cause now the end will live forever in my Jag tools toolbox. :slightly_smiling_face:
wow! digress, back on track
I traced the bearing preload nut onto the steel. then cut the steel in half. then on my portable band saw I cut out the nut, shape (which is 1 7/8" or 47 mm) filed off the sharp edges, then welded it back together. then welded on a cap at the top, cut the corners off and tried to make it round; then welded on the 3/8 drive extension end.
I’d never welded around a pipe before, wow! that’s not easy;
(Mark Lee (Pay Pal Patron)) #219
Well, part 2 of the carrier assembly is up on my youtube channel Jag Mods. This actually has a Jag Mod… It’s a premier moment :boom:
Next will be using the tool I made to set the preload; and set the preload on the hub bearings too. It’s a day of getting loaded… Preloaded… Bad pun… sorry.
Thank you all for your support and help. I would’ve never taken on such an undertaking with out the confidence I got from knowing you all are here to help a fellow Jag owner. This is truly a fellowship! For that I am grateful.
Sincerely,
Mark
(Frank Andersen) #220
Ingenious, Mark…
However; do you have the torque preload specs to use these tools meaningfully…
Frank
(Mark Lee (Pay Pal Patron)) #221
I do! :slight_smile: starting at 4 inch pounds rotate the output shaft assembly and tighten 3/16 of an inch at a time until virtually all the endplay is gone, not to exceed 6 inch pounds. That is according to The Green Book. I’m planning on doing a video on that too.
