Looking for a refurbished Differential (LSD)
(swallow_che) #21
I just went to a mechanic for checking the pinion.
God lucky! The noise wasn’t from the diff… (there still is some boiling(?) noise from diff though)
It was from the right rear wheel.
I found this article from this forum.
Sounds like exact same as mine but only mine is not cured.
I am guessing that it’s from the caliper or handbrake shoe?
Hub bearings are new, btw
(Andrew Waugh) #22
Or this:
It’s just a bit of 1/4" barstock with a hole to suit the flange bolt in it (the other end has a smaller hole for larger flanges).
(Grooveman) #23
Andrew …
Yes you definitely need something like that to keep the differential from turning… but you still need some serious leverage to tighten the piñon bolt …
.de4ccedc52a00a2ba80a23316ecc5266
